This is Ben Brown, he had a near fatal atv crash in 2006 that left him a paraplegic. With the help and support of his friends and family as well as the doctors and therapist, this video was taken in 2007. Just over a year later.
[ame=http://www.youtube.com/watch?v=LqfgveF1LTU&feature=related]YouTube - Ben Brown A.T.V comp. 2[/ame]
    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Hungus
      Hey guys, I know a 2000 Yamaha Big Bear 400 4x4 5 speed single range transmission is model: YFM400FM
      But what is the model designation for:
      2000 Yamaha Big Bear 400 4x4 "Professional" 5 speed dual range transmission...   YFM400F??
      VIN decoders don't seem to work for this Yamaha I picked up.
    • By edb6969
      View File 1999-Later Honda TRX400EX Carb/Cable Removal
      1999 - Later Honda TRX400EX Carb/Cable Removal Supplement
      Submitter edb6969 Submitted 11/02/2020 Category Honda ATV
