Cali. desert rat learning that real trees are a lot like the ones on H.R. PuffnStuff. They just reach out and grab you!!:shock2::shock2:
Hoping by spring we will have some good tracks worn in before ole Mother Nature gets all roided out and turns the trails into jungle,....AGAIN!:aargh::aargh::aargh:
The wife is already in here but I guess she didn't want me to know:confused: But just the little I've read it seams like a cool site. Can't wait till the shooting:shoot::shoot: slows down enough to start ripping it up again:yes::yes:
Might just put on paddles and dune it till bambi says it's safe to go back in the woods :drivingc:
    • By Elk
      2002 Polaris Magnum 325
    • By middlebrookgt
    • By T37Mark
    • By superdude811
      Can you put tracks on manual atvs? would it be effective? is 280cc enough to even move them? thoughts/suggestions?
    • By DaveswMN
      Thanks for any thoughts.
