Similar Topics
By Atvguy0901
Thank for the add on quad crazy. I am new here and need some help with my atv. It’s a older Yamaha Timberwolf 250 that I purchased second hand from an person. I got it home ans started to look into it. He stated it needed a cdi box so I ordered one for it and a battery as well also a key switch cause it did not come with one. I put all the parts on it and when I hit the start button it just clicks and noting else. Thank you any help is appreciated.
By Gwbarm
Still working on the 2000 Big Bear with a no spark issue. A lot of this has been covered in an older thread, but I will summarize.
Bought it with the previous owner telling me it needed a new wiring harness, but the wiring harness was in tact and seemed to be fine, except starter solenoid and coil was missing, also the engine was stuck, and no spark plug. Got the engine free and rotating, checked compression, it was 130, not great, but good enough to run. Hooked up a battery, nothing , went through all the wiring and found starter cutout relay bad, replaced that, now I have it rotating with starter. Pulled the plug checked, no spark. Checked start/stop switch, working like it should, reverse relay was bad ,replaced that. Checked continuity from coil to CDI, good, checked pickup coil resistance, within specs, checked anti kickback coil resistance, within specs. What am I missing.
By ATVNetwork
Round two of the ATV Motocross National Championship Series, an AMA National Championship, (ATVMX) remained South and set its sights on returning to the Gatorback Cycle Park facility in Alachua, Florida. The return to this track had racers excited about getting onto the second round of AMA Pro Racing, and would be the season kickoff for amateur, youth and vet racers as a full schedule of racing was scheduled. View the full article
By EugenM
Hi, I have a grizzly 600 from 2000 that has been giving me headaches for a few days. it has no spark. I checked everything I could according to the manual and everything was within the parameters and I came to the conclusion that I need to replace the CDI .... when I did the measurements I did not check if the orange cable that goes from the CDI to the induction coil has a connection to ground (I just checked if it had continuity and it did). after I put a new CDI and I still had no spark, I saw that somewhere under the fuel tank there was a bunch of cables that were a bit crushed and there that orange cable was stripped and had a connection to the chassis. what are the chances that the new CDI will be fried because of this?
Thanks!
By allonmorris
Hey guys,
I have a 2002 yamaha wolverine that needs a new wire harness. Does anyone have a clue where i can get one new or used. ive looked all over and cant find much on a 2002 model.
Any help will be greatly appreciated.
Thanks in advance!!!
Similar Tagged Content
- 3 replies
- 26,095 views
- 4 comments
- 2,378 views
- 6 comments
- 2,218 views
- 0 replies
- 6,438 views
- 0 replies
- 1,768 views
Gallery Images
