You might be a Redneck
By middlebrookgt
By mbirt
Hey all,
Just picked up two dead mid-90's Kawasaki Bayou 220s for $250. Already have one running on starting fluid and it sounds healthier than expected. Moving onto a thorough carb cleaning and refurb of the brakes next. These are our first ATVs and we're excited to make family memories on simple, approachable machines on our newly acquired land.
In case anyone reads this, is it worth rushing to 10 posts here to get the Bayou 220 FSM if I already have a Bayou 250 FSM?
Thanks,
Matt
By Frank Angerano
This is a good question asked by @Johnny Chancellor. I put it in a new topic so it does not get lost. We all know we need a cdi box but I bet a lot of the members here don’t know how it works. This is a good explanation of a cdi box including what it does, how it works and what “cdi” stands for.
Ive posted two links here. Feel free to add to the list!
https://www.elprocus.com/capacitor-discharge-ignition-cdi-system-working/
https://en.wikipedia.org/wiki/Capacitor_discharge_ignition
By remnar
New member here,
I have searched here and other places and have not found an answer to my problem. As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC. I shows a 8-1 which is a TPS error. This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v. It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light. However, there are no PS codes of that value. This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
A couple questions. First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
Second, anyone used a OBDII reader with an a 4pin adapter to pull codes? If so, what system do you use?
Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
By Jas
Hi from Australia. My parents have an ancient trx300 from 1989 that was made in Japan. We just picked up a 1995 trx300 to replace it with and I noticed this one was made in USA.
What I’m wondering is if they were being built in Japan and USA at the same time or did all manufacturing move to the states? I’d love to hear any information about this.
Thanks!
