    • By Rick Shropshire
    • By shorty
      I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
    • By Need-help-with-quads
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By JakeWens
      I’m pretty sure it’s an 01, that’s what it looks like based on some of the parts I’ve gotten for it already. I’ve been chasing a no spark since I got it, I bypassed the kill switch, I replaced the CDI, the voltage regulator, and the ignition coil. The battery is new, the headlights work so I know there is power leaving the battery. I’m not sure what else to do or check, I’m a heavy equipment mechanic but little a guy gf like this throws me for a loop, any help is definitely appreciated
