:norwayflag:
I'm usually not a winner type, I guess I was standing in the front of the lineup, when they passed out winner luck. (Door hit me when they open it) Thanks to everyone that voted for my picture in January contest. This time im a winner
Have a nice day folks
Edited by Shortcut
well.
:dammit:
*Magazine subscriptions can only be sent to US and Canadian residents
maybe im not so lucky after all :laugh:
Its ok, i can read them in september when i get to Colorado
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By HHurks
      Hi to all
    • By wjmedic
      right front hub again
