for the most part i dont think it would be too hard... there are a bunch of guys out there swaping in busa 1300's in them so room shouldnt be an issue... some other thing you might think about are wiring and controls (clutch, trottle, shifter).. im sure if you search a little there will be a quite a bit of info out there...
    • By toe420
      Hello everyone, I have a 92 honda trx350 I just picked up that has a bent section of the frame where the rear of the seat would clip into place. It almost looks like a tree or something heavy fell on it. Its a fairly deep bend, if that makes sense. It like a V instead of straight. What are peoples goto methods for straightening a section like that?
    • By davefrombc
      It would be  helpful at times to have a button  where we could cont the Admin. to  make some changes to  our posts.
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
    • By mga
      I have a Yamaha Big Bear 400 4x4 2000.  I've posted on here about the frame being bent. Does anyone know what year frames are interchangeable? Also, would the frame from a 350 be the same as a 400? Would it matter if it was a 4x4 or 2x4?
      thanks for any help with this
    • By onequad
      i got a 93 400 Kodiak the frame on one side is rusted out.  is this a comin thing? was wondering if it worth the  tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
