I have a Yamaha Big Bear 400 4x4 2000. I've posted on here about the frame being bent. Does anyone know what year frames are interchangeable? Also, would the frame from a 350 be the same as a 400? Would it matter if it was a 4x4 or 2x4?
thanks for any help with this
i got a 93 400 Kodiak the frame on one side is rusted out. is this a comin thing? was wondering if it worth the tumble to put in a used one. I'm worried most of the bolts will brake. it don't look the rusted over all. just the part were the frame boke in half. do all kodiaks have the same frame
Is it possible to put a motor from a big bear 350 into a timberwolf? Reason I ask is that I have a timberwolf with a bit of a rod knock, and I have big bear with a bad rear end and axle with a good motor. So, is it possible?
