MEDIA RELEASE
RECREATIONAL GROUPS FILE TO ENTER UTAH DESERT LAWSUIT
Contact: Paul Turcke 208-331-1800
Date: April 8, 2009
WASHINGTON, DC - A coalition of recreational access groups moved today to join a lawsuit challenging Bureau of Land Management (BLM) plans covering nearly seven million acres in Utah. The motion was filed by the Trails Preservation Alliance (TPA), Colorado Off-Highway Vehicle Coalition (COHVCO), and BlueRibbon Coalition (BRC), all trails-based, grassroots recreation advocacy groups. The lawsuit was filed by eleven preservationist groups, led by the Southern Utah Wilderness Alliance. Through the suit, the plaintiffs hope to have the BLM plans declared illegal and set aside, and ask the Court to issue an injunction preventing activities authorized by the plans until BLM issues new decisions complying with a host of federal statutes. The lands at issue are located in the BLM Moab, Price, and Vernal Field Offices, which include iconic destinations for all types of backcountry recreationists.
"Our groups have carefully participated in these planning processes," said Don Riggle, TPA founder. "We are far from satisfied with the final BLM decisions, but can obviously see that SUWA is attempting, through this suit, to close off access to even those trails that survived the designation process," Riggle concluded. "Our courtroom relationship with SUWA stretches back nearly a decade, and this suit seemingly breathes continuing life into that relationship," added Brian Hawthorne, BRC Public Lands Policy Director.
The lawsuit was originally filed on December 17, 2008, and targeted 77 lease sales for oil and gas drilling on BLM-managed lands. Those sales were halted by a temporary restraining order issued by the Court on January 17, 2009. The latest complaint, filed March 19, 2009, drops the claims against the oil and gas leasing projects, which BLM has apparently withdrawn. However, the current complaint adds claims addressing other uses, including off-highway vehicle use.
The Recreational Groups and SUWA have waged prior battles over BLM's management of Utah lands, most notably including a 2000 lawsuit by which SUWA sought to compel agency action meeting SUWA's vision of that required by BLM. In that suit, the Recreational Groups filed a motion to dismiss the case on jurisdictional grounds, which was granted by the U.S. District Court for the District of Utah, reversed by the Tenth Circuit Court of Appeals, but ultimately affirmed by the U.S. Supreme Court in 2004. During and subsequent to that case, BLM has been preparing the land use plans and travel management designations now under challenge in the present suit.
The Trails Preservation Alliance is a nonprofit organization dedicated to protecting the sport of motorized trail riding, educating all user groups and the public on the value of sharing public lands for multiuse recreation, while protecting public lands for future generations. Colorado Trails Preservation Alliance - Home
COHVCO is a nonprofit organization whose member enthusiasts, organizations and businesses collectively comprise over 200,000 Coloradoans and regular visitors to Colorado and other western states who contribute millions of dollars and thousands of hours annually to off-highway vehicle recreation through registration fees, retail expenditure, project participation and related support. Colorado OHV Coalition
The BlueRibbon Coalition is a national recreation group that champions responsible use of recreation, and encourages individual environmental stewardship. It represents over 10,000 individual members and 1,200 organization and business members, for a combined total of over 600,000 recreationists nationwide. 1-800-258-3742. BlueRibbon Coalition: Preserving your recreational access to public lands.
    • By quadnut20
      Here's a couple of pics of our ride !!
      April 15_2026-04-15.mp4
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
      I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
      Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
    • By Daniel1971
      I have a 2009 Honda rancher that has fuel coming out of the injector but will not crank. I can spray gas in through the breather and it will run a few seconds. Any help appreciated
    • By smallmotor2002
      Hello everyone.
      I'm working on a 2014 Yamaha 700 Grizzly and having no luck accessing the diagnostic mode on the display. I have tried with the fuel pump connector plugged and unplugged, and select and reset buttons depressed simultaneously for up to 30 seconds with no luck.
      I could sure use some assistance if anyone has any tips on this
