Wicked450r (November)
-Body-
Plastic-Stock
Handguards-none
Graphics-Rath Racing/Insaneatvs
Seat Cover-Stock
Numbers-none
Bar Pad-Fasst company
Fuel Tank-stock
-Chassis/Control/Suspension-
Frame-Stock
Steering Stem-Rated X +1"
Hubs-R.I.S. Designs
Handle Bars-Flexx Bars
Throttle-R.I.S. Designs
Clutch Lever/Perch-Magura
Grips-O.D.I. Rogue
Nerfs-AC Pro pegs w/heel guards
Bumper-AC
Grab Bar-R.I.S. Designs
A Arms- +2+1 FullFlight
Front Shocks-Stock
Rear Shock-Stock
Swingarm-Stock
Axel Carrier-stock
Axle- G-Force +4
Brake Lines- Galfer
Axel Locknut-stock
Rotors F/R-stock
Rims F/R-stock
Tires F/R-stock
Stabilizer-SRP
-Engine and Drive-
Cylinder-stock bore for now
Head-ported
Bore-stock
Stroke-stock
Displacement-450
Carburetor-stock but jetted
Air Box-stock w/o lid
Air Filter-K & N W/outterware
Case Vent filter-K & N
Pipe or Silencer-Rossier Full Polished
Clutch/Plates-Magura Hyd. Clutch/stock plates
Gearing F/R-14/38
CDI-stock
Kill Switch-Pro Designs
Cooling system-stock with engine ice
-Other- please list.
Billet Air filter ring
Billet engine mounts
Drilled T-Valve
HRC Air lid
HRC Cam
HRC Needle
Polished Kicker
Trail Tech -4 oz. Flywheel
Billet Spocket hub
Modquad Billet chain guard
Polished Gear shifter
Anti-vibe cone
Driven Products Knobberz Bar ends
Billet Brake line clamps
Polished Brake pedal
R.I.S. Designs Billet Brake res. cover
R.I.S. Designs Billet Parking Brake block off
110 octane Race gas
Billet case saver
Billet Gas cap Vent
Billet Oil Fill Cap
Flamed Project 321 Gas cap
HRC Needle
LSR Key plate
Polished Warning labels
R.I.S. Designs Billet Clutch cover
R.I.S. Designs Billet Flag Holders
R.I.S. Designs Billet Grab Bar
R.I.S. Designs Billet Radiator cap cover
20x11x8 Sand Devils
20x11x8 Sand Sharks
22x8x10 Dune Trackers
8X9 Rear Douglas Old school
Billet Piston valve caps
Douglas front wheels
Douglas rear wheels
R.I.S. Designs Billet Front Lug nuts
Crapo85 (December)
-Body-
Plastic-Yellow Fullbore
Handguards-Yellow Powermadd
Graphics-Nasus
Seat Cover-Stock Modified
Numbers-n/a
Bar Pad-Joker
Fuel Tank-stock
Frame-Stock
Steering Stem-Stock
Hubs-Stock
Handle Bars-Pro taper
Throttle-Moose
Clutch Lever/Perch-Fly
Grips-Oury
Nerfs-Ac
Bumper-Stock
Grab Bar-Stock
A Arms-Stock
Front Shocks-Works spring kit TPS/zps
Rear Shock-Works spring kit Zps
Swingarm-Klein Racing +2
Axel Carrier-Stock
Axle-Stock
Brake Lines-Stock
Axel Locknut-Stock
Rotors F/R-n/a- stock
Rims F/R-Stock dirt/ sand douglas 8x6 .125
Tires F/R-F- stock R- turf tamers/sand 22*11*8 8 paddle haulers
Stabilizer-n/a
-Engine and Drive-
Cylinder-Athena
Head-Hp porting,Hot cams stage 3,Kibblewhite spring&valves
Bore-97mm, 14:1 venom
Stroke-+3
Displacement-501cc
Carburetor-44 lectron
Air Box-n/a
Air Filter- Ron wood
Case Vent filter-K/N
Pipe or Silencer- Ron wood
Clutch/Plates- EBC
Gearing F/R-13-39
CDI-Stock
Kill Switch-honda dirt bike
Cooling system-In-line aluminum cooler
Cold fusion nitrous 20 hp shot
Lazer lights
piaa h6m bulbs
lots of powder coating
See thru clear and billet gas cap
Modquad park brake block off
Thats is most I can think of know!!
  • Admin unpinned this topic
      PUMPKIN 10% OFF on orders $99 or more! (valid till 10/26/2011 to 11/16/11)
      SEAALX1 Free Shipping on orders worth $50 (1-Nov-11 to 6-Nov-11)
      DEBALX1 $10 OFF on orders worth $50 (8-Nov-11 to 13-Nov-11)
      AEBBLX1 20% OFF on orders worth $150 (11-Nov-11 to 13-Nov-11)
      BECALX1 15% OFF on orders worth $150 (15-Nov-11 to 20-Nov-11)
      Click Here to check out JC Whitney!
      November 2010 ATV Photo Contest Vote
      Theme: "Through Water" with your ATV, 3 wheeler, or UTV.
      Prizes Include:
      ATV World Magazine & ATV 4-Wheel Action Magazine Subscriptions
      (1 year subscriptions)
      Rocky Mountain ATV $25 Gift Card
      Quad Life Sticker - Sponsored By: robdcol. More Info Here.
      (your choice of one, of the two below)
      Voting will end November 30th, and the winner will be announced!
      Ajmboy
      Stoopidbot1
      PAQUADNUT
      wylde1
      greasemonkey259
      quadmaniac
      mikeexplorer
      sinned96
      Holeshotr15
      BuckBilly
      Rinconrecker
      DirtDemon
      Prizes Include:
      Rules: Submit your "Through Water" photo with your ATV, 3 wheeler, or UTV, by entering it with a post, into this thread. (If you are not familiar with how to do this, visit the Learning Center) One photo per member allowed, so make sure it's a winner. You may submit photos that have not won past contests. Photos can be of yourself or taken by you. You may not submit photos that you do not have ownership of or permission to use. Any violation of these terms will result in disqualification.
      Last day to enter a photo is November 26th.
      Voting will take place for the last 4 days of November to determine the winner.
      Good Luck!
    • By GlamisTrips
      Hey guys, we are planning a trip from Florida to Glamis, CA. Truck and trailer are leaving the Sarasota area around October 17th. Your machine will be out there October 24th-November 2nd. Your machine is insured to and from the Sand dunes. Your machine will be out there the full 10 days but you can come and go as you please, even stay for a long weekend if thats what you can work out. We have about 25 spots left. A spot generally consists of one quad or two dirtbikes. Call or email for more info.
      www.glamistrips.com
      November 2009 ATV Video Contest
      Sponsored By:
      Theme: "Best Video" with your ATV, 3 wheeler, or UTV.
      * Video MUST be uploaded to QUADCRAZY here.
      * Your video should not be longer than 4 minutes.
      * Your post entry must include the video url page and a description of your video.
      * One video per entry.
      Prize: ATV&SXS Illustrated and UTV OffRoad Magazine Subscriptions
      Please visit our sponsors: ATV&SXS Illustrated and UTV OffRoad Magazine
      Rules: Submit your "Best Video" with your ATV, 3 wheeler, or UTV video by entering it with a post, into this thread. One entry per member allowed, so make sure your entry is a winner. Video can be of yourself or taken by you. You may not submit a video that you do not have ownership of or permission to use. Any violation of these terms will result in disqualification.
      3 ways to get your video to QUADCRAZY:
      1. You can upload a video from your pc here.
      2. Import it from sites like YouTube, if it is there...click here.
      3. Have your video stream from another site...click here.
      Then take the url of the page that your video is on, and enter it with a post into this thread...along with a description of your video. just copy and paste the url.
      * If you run into issue uploading your video, please contact us at [email protected], we will help you.
      *By entering this contest, you allow QUADCRAZY the right to use your video for marketing purposes, ex. Front page advertisements, banners, etc.
      Last day to enter a video is November 26th.
      Voting will end November 30th and the winner will be announced!
      Good Luck!
