      QUADCRAZY NEEDS YOU!
    • By mikeexplorer
    • By Ulfthednar
      Got others in the works.
      Been years since I really played with editing software and content creation. ATV+Gopro+Davinci.
      https://youtu.be/-JV-xEq9uW8
    • By David Cameron
      The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump  Any ideas would be really appreciated.
    • By DayBreakJim
      20230725_171507.mp4
