What women really mean.
Guest Fox300exchic
What do you think?
Fine
This is the word women use to end an argument when they are right and you need to shut up.
Five Minutes
If she is getting dressed, this is half an hour ... .
Five minutes is only five minutes if you have just been given 5 more minutes to watch the game before helping around the house.
Nothing
This is the calm before the storm. This means "something" and you should be on your toes. Arguments that begin with "nothing" usually end in "fine".
Go Ahead
This is a dare, not permission, DON'T DO IT!
Loud Sigh
Although not actually a word, the loud sigh is often misunderstood by men. A "Loud Sigh" means she thinks you are an idiot and wonders why she is wasting her time standing here and arguing with you over "Nothing".
That's Okay
This is one of the most dangerous statements that woman can make to a man. "That's Okay" means that she wants to think long and hard before deciding how and when you will pay for your mistake.
This is the least used of all words in the female vocabulary. If a woman is thanking you. Do not question it, just say you're welcome and back out of the room very slowly.
    • By BillR94
      Thank you for your time
      Bill
    • By shorty
    • By wjmedic
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
