  • 6 months later...
      QUADCRAZY NEEDS YOU!
    • By mikeexplorer
    • By SouthARriverRat
      Looking froward gaining more knowledge and seeing projects being built. Currently resurrecting some kind of Suzuki 230 quad. I believe. lol. Been sitting at the edge of the woods for 15+ years. Riding a all original 84 Honda atc 110
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
