Hi I have a 2000 big bear 400 and i just put a new carburetor on it and it idles fine but when you try to accelerate it sounds like it is going to die, so when it sounds like it is going to die I will give it more throttle then it will go just fine.
hey fellas new guy here, i just picked up my first wheeler ever, it a 2000 quad runner 500.... when pushing the starter button the starter would turn but not turn the engine over...so I was thinging it was like the one of the many automotive starters iv repaird that the bendex was not advanceing...as you guys prob already know it not like an automotive starter...... so the other day i pulled the startrer off the bike to see about getting it working...turns out the case the the starter gear come's out of is just empty, no flywheel gears or anything to be seen to connect starter gear to crank shaft.....
so my question is this, what do i need to get this working, i know im getting into the side of this motor to do the repair i'm just look for some thougth's...
thanx...
