By Asand211
By TravisCr
I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but I got a good deal on the quad and a plow so I went for it
By Chucksta
Any ideas?
By jmeier1981
Ok guys Ive got a few more for ya.
TIRES:
Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
WHEELS:
Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
SNORKEL:
I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
By Clydaho
2022 Sector 550, 414 miles on it and the gas gauge reads empty. I topped off the gas and it didn't change.
There is no fuse that I could find. No access at the gauge cluster.
Has anybody removed the tank lid? Any tricks?
Any other ideas?
Thanks for any help,
Clyde
