i never did anything to it i think a sensor just got wet when i was in water and now it is running fine havn't had the problem yet hopfully its fine
Hopefully it stays that way...:wink:
    • By toe420
    • By Coyote251
      any ideas how to correct
    • By digrig
      Hey everyone,
