Algona, WA– (10/01/2009) Vision X Lighting has launched the Reflex, the brightest, most efficient and versatile LED lighting system. Each light utilizes new 10-Watt LED technology providing ultra-bright 900 lumens per LED with the lowest amp draw. Available in seven sizes from 6" to 52", and only 2.5" tall by 2.5" deep, the Reflex is designed to fit in the tightest places. Mounting the Reflex
More...
    • By OldATVowner
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
      any ideas how to correct
    • By T37Mark
    • By hunky
      Thanks for looking!
