Could be a sensor or a wire, but my best guess would be that whatever moves the needle itself is broken. I would check the sensors, wires and plugs, if everything looks ok, then I would take the speedometer assembly itself apart and inspect the inside.
    • By docdoug72
    • By oxidized_black
      Engine
      Chassis
      Size
      Basics
      Features
    • By Sportsman500guy
