I got a pre-declined credit card in the mail.
I ordered a burger at McDonalds and the kid behind the counter asked, "Can you afford fries with that?"
CEO's are now playing miniature golf.
If the bank returns your check marked "Insufficient Funds," you call them and ask if they meant you or them.
Hot Wheels and Matchbox stocks are trading higher than GM.
McDonalds is selling the 1/4 ouncer.
Parents in Beverly Hills fired their nannies and learned their children's names.
A truckload of Americans was caught sneaking into Mexico .
Dick Cheney took his stockbroker hunting.
Motel Six won't leave the light on anymore.
The Mafia is laying off judges.
Exxon-Mobil laid off 25 Congressmen.
Congress says they are looking into this Bernard Madoff scandal. Oh Great!! The guy who made $50 Billion disappear is being investigated by the people who made $1.5 Trillion disappear
The economy is so bad, a picture is now only worth 200 words.
It's so bad, Snoop Dogg had to start eating regular brownies.
The economy is so bad, I saw the CEO of Wal-Mart shopping at Wal-Mart.
The economy is so bad, I went to my bank the other day and the teller handed me a note saying, "This is a robbery!"
The economy is so bad, George W. Bush appeared in a flight suit and declared economic recovery was complete.
The economy is so bad, Bill Gates had to switch to dial up.
The economy is so bad, Dick Cheney took his stockbroker hunting.
The economy is so bad, Dr. Seuss rose from the grave to write a new book: Green Eggs and Spam.
The economy is so bad that I went to my bank to get a loan, they said, "What a coincidence! That's just what we were going to ask you!"
The economy is so bad, rapper 50 Cent had to change his name to 10 Cent.
The economy is so bad, Barack Obama changed his slogan to "Maybe We Can!"
The economy is so bad, my ATM gave me an IOU!
The economy is so bad that the highest-paying job in town is jury duty.
The economy is so bad I saw a man in Costco buying one roll of toilet paper.
The economy is so bad that I saw a van full of legal immigrants illegally crossing the border to Mexico.
The economy is so bad, I became a Pastafarian hoping that a meatball will appear to me.
The economy is so bad that parents in Bevery Hills are considering raising their own children.
The economy is so bad that even people who aren't in Barack Obama's cabinet aren't paying taxes.
The economy is so bad I saw a polygamist with only one wife.
The economy is so bad that I saw someone using the sun to get a tan!
The economy is so bad that wives are having sex with their husbands because they can't afford batteries.
    • By middlebrookgt
    • By Hagbard
      Looking for a DRIVE SPROCKET RETAINER PLATE for a 1987 LT230E (P/N 24751-35B01)? Good luck.
      Believe me I searched high and low, including contacting two OEM suppliers in Japan. No dice.
      Ran into this problem myself. The part is no longer available, unless you get SUPER lucky on eBay.
      My solution was to use the identical part from the newer ones, but you have to switch out the bearing and spacer bushing as well. Basically I took the retainer plate (46) and spacer bushing( 55) from a 160 motor I have for parts, and bought a new 6206 bearing which is the right size to match part (40) https://www.amazon.com/Bearing-30x62x16.../dp/B07XJ7H2VJ There's also a difference in thickness between the sprockets, so I added a couple 14ga. bushings as spacers
      So, referencing this parts diagram, you need to get everything from the bearing (40) on out. So, parts 40 (BEARING 09262-30084), 46 (RETAINER 24751-35B10), 47 (OIL SEAL 09283-38017), 48 (O RING 09280-70009), 54 (O RING 09280-21008), 55 (SPACER 27531-35B10), and 59 (PLATE, FRONT CHAIN GUIDE 27641-35B00).
      https://www.babbittsonline.com/.../50d08495f.../transmission
      If you need me to walk you through any of it I'd be happy to help.
    • By Boss_Mare
      Hi!  I just purchased a 2018 Polaris Sportsman 450 AWD. The instrument cluster reveals 306 miles, ENG 75.5 hrs, and Service Due 83.4.  Oil and coolant are clean and levels are good.  Air filter is also clean.  Everything shows the ATV is in excellent working order.  But... every time I start it, the check engine light lights up (no code is displayed).  I am worried the light may indicate something serious, but I can't figure out what.  Any ideas/suggestions will greatly be appreciated.
    • By LT-4WDinNY
      I got the side cover off, learned how to put the subtransmission back together. I took the nut off the crank. Grabbed the new flywheel puller. Put the small piece on to protect the crank shaft end, and the flywheel fell off on its own??? So that was weird. I then looked and tested the starter one way clutch. It wasn't in pieces like I had seen on others on YouTube. It only turns in the one correct direction as indicated by the arrow. However, it looks like maybe it is slipping under load? Is that possible?
      I know that it was very difficult to pull start since I bought it back in 2001. The guy I bought from had the receipts on a recent engine rebuild by our local Suzuki dealer in the $1200 range because they put the oil filter in backwards. Anyhow, I am trying to make it easier for my kids to ride. I think I verified that the starter clutch was bad by removing the electric starter, then it would pull start normal...
      I took pictures of the one way clutch and the CALTRIC replacement parts I bought off Amazon. Looking closer, appears to be heavy wear on the metal pieces in the clutch and scratches on the starter gear surface that goes inside the clutch. I am going to replace the OEM parts with the CALTRIC brand parts off Amazon.
      However, I found some other discerning things behind the flywheel. Looks like the center case has cracks, and one broken off tab with the other 2 worn? Also it looks like some scraping inside the case bottom right... assume from when the post broke off.  The post was NOT in the case, so probably occurred prior to the Suzuki Dealer rebuild.  Also some discoloring on the crankshaft and back of starter clutch.  Again, putting in the CALTRIC brand replacements for the starter clutch and starter gear as a set.
      Thanks!
      Bruce
