Guest Fox300exchic
SMART AS* ANSWER #6
It was mealtime during a flight on Hooters Airline.
"Would you like dinner?" the flight attendant asked John, seated in front.
"What are my choices?" John asked.
"Yes or no," she replied.
SMART AS* ANSWER #5
A flight attendant was stationed at the departure gate to check tickets.
As a man approached, she extended her hand for the ticket and he
opened his trench coat and flashed her.
Without missing a beat, she said, "Sir, I need to see your ticket not your stub."
SMART AS* ANSWER #4
A lady was picking through the frozen turkeys at the grocery store
but she couldn't find one big enough for her family.
She asked a stock boy, "Do these turkeys get any bigger?"
The stock boy replied, "No ma'am, they're dead."
SMART AS* ANSWER #3
The cop got out of his car and the kid who was stopped for
speeding rolled down his window.
"I've been waiting for you all day," the cop said.
The kid replied, "Yeah, well I got here as fast as I could."
When the cop finally stopped laughing, he sent the kid on
his way without a ticket.
SMART AS* ANSWER #2
A truck driver was driving along on the freeway.
A sign comes up that reads, " Low Bridge Ahead."
Before he knows it, the bridge is right ahead of him and he gets stuck under the bridge.
Cars are backed up for miles. Finally, a police car comes up.
The cop gets out of his car and walks to the truck driver, puts his hands
on his hips and says, "Got stuck, huh?"
The truck driver says, "No, I was delivering this bridge and ran out of gas."
SMART AS* ANSWER OF THE YEAR 2006
A college teacher reminds her class of tomorrow's final exam.
"Now class, I won't tolerate any excuses for you not being here tomorrow.
I might consider a nuclear attack or a serious personal injury, illness,
or a death in your immediate family, but that's it, no other excuses whatsoever!"
A smart-as* guy in the back of the room raised his hand and asked,
"What would you say if tomorrow I said I was suffering from complete
and utter sexual exhaustion?"
The entire class is reduced to laughter and snickering.
When silence is restored, the teacher smiles knowingly at the student,
shakes her head and sweetly says, "Well, I guess you'd have to
write the exam with your other hand."
  • 4 years later...
SMART AS* ANSWER #6
SMART AS* ANSWER #5
SMART AS* ANSWER #4
SMART AS* ANSWER #3
SMART AS* ANSWER #2
Thats not correct as a completed bridge exceeds the gvwr of any highway vehicle. So I dont know why this driver told the officer that
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By wjmedic
      right front hub again
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
