By HoldenBoy
Hi all,
By prdicon
Polaris it a bit cheaper.
Let's say 3-5 years from now.
By crankin
By Asand211
I've got a 1995 220 Bayou and the electric start does not work. When I got it the machine was pretty rough but I was told it ran less than a year ago. The key switch had been cut off and wires twisted after the key was lost. I bought a new ignition switch and repaired the wiring and it is working correctly. It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button. I verified there is no voltage going to the starter from the solenoid. The fuse in the solenoid is good. Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on. That doesn't make sense to me but I could be wrong. I would appreciate any help I can get. Thank you in advance.
