Similar Topics
By DarkRider
Hey everybody,
Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
Also just keep in mind this is coming from someone not super mechanical.
Key factors:
Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
By FalloutBoy
I can't find a diagram for my Can-Am, all the diagrams have different color coded wires and are missing the necessary parts to fully re-wire my Can-Am. Any help would be appreciated
By BuckBilly
By MLG
Engine starts and idles fine. When I give it throttle it spits and back fires thru carb. I replace the carb. Replaced stator, spark plug. Check gas flow. Checked voltage 13.6, please help
By Charlesbrown
Similar Tagged Content
Gallery Images
By CK1999_400ex,
By DJLime,
By Firewalker,
By berryjo5,
By Guest,
By zukeracer,
By onetoughzuki,
By chopt,
By adammiles,
By Suzuki450rMan,
By shane36,
By osbornk,
By splinter,
