By jen
Wow...I packed a small soft side cooler with an ice pack at -4 F and inserted my Type K thermocouple sensor inside so I could monitor the temperature without opening. After 3 hours the inside temperature was 60 F...OMG! The ice pack was solid frozen. Standard temperature for safe storage is < 40 F. What I found by asking was that there should be no air space in the cooler. Packed with Ice preferably ice from connivence store (normally 0 F of less). Food should take up short day trip1:1 ratio.
Good coolers are expensive.
By jay41198
By tepin
By Shorty51
By Rockbottom
Any body have a part number for replacing the safety interlock on the left brake so you can start the engine with the brake handle pulled and in gear
or how to bypass this function so you can start in gear
thanks ahead
