Need help with an '84 LT 250E
Similar Topics
By dlgg7
I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ??? -
By 86096
I have a 1985 Suzuki lt230ge with electric start. It has a keyed ignition. The key, once inserted will move to two positions. There is a button on the left handlebar to engage the starter... so what do the two key positions do. Anyone know???? I am looking forward to getting to enjoy this machine but I can't find a lot of info online about such a classic ATV. Thanks in advance for any advice!!
By Gwbarm
By gohndd
Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
Gallery Images
By mike83,
By nemesis,
By Guest,
By cjsservices,
By trouble4fun,
By Guest,
By blahhhh,
By mike83,
By monkey420,
By Chomp,
