Guest martinb
Going to have to get some new tires for my '98 Recon. I have read somewhere about the feasibility of larger tires. anybody have any experiences with using larger tires? I know that there is a limit on how much larger you can go. Any advice would be appreciated. Thank you, martin
Really depends on what you want to achieve. I woudl sugest a set f tires that are bit more aggresive than stock. You canalso get a set of tires and rims as a package.
* Added year, make, and model, into your thread title.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By BillR94
