Looking for a little insight for what appears to be a fuel issue. Quad starts fine and idles fine, however when riding, it will run fine for about 3 to 4 blocks and starts sputtering and dies. If you give it a couple of minutes it will fire back up and run fine for 3 to 4 blocks and the same thing occurs. Is it possible it would be the petcock is bad?
Thanks Pineknot
Edited by pineknot
lack of description
Thanks for the suggestion, I'm really confused on this one. I pulled the line off from the carburetor and started the engine, fuel drizzled out in prime and pumped out in the on and reserve position. I've checked the vacuum line to the petcock and the vent line off the carburetor. I'm beginning to think i may have a weak diaphragm on the fuel pump. I'm not sure how to test the fuel pumps vacuum without special equipment. Open to any suggestions.
Thanks Pineknot
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By Dumass
