hello i have a big bear and i am restoring it. it runs good everything on the handle bar switches work except head lights, i noticed coming out of the hi=lo switch a red wire has been cut or torn off and i cannot find a spot on the frame harness as to where it goes. i have searched hi-lo all over this thing can someone help locate the other end of the wire or help me tie it in somewhere....thanks sorry my first post is a help thread. here is a pic.
The only thing I can suggest is keep tracking the wire group until you find the red wire, or take the switch assembly apart and see if the red wire was added on, maybe it isn't original. Check the wires at the headlight, is one of them red?
    • By Thumpinhard25
    • By fwsamm
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
