Cooling fan question for 2005 Eiger LT-A400
By rjsummer
By Arizona
By middlebrookgt
By Olchap
Hi, I am new to this forum and I am happy to be here. I purchased a Yamaha 350 Big Bear without a title and I cannot find a Vin number to find out what year it is. I am hoping someone here can help me identify this atv. I checked on the main frame near the front A-arm left side found nothing. I checked up near the radiator and found nothing. Where else should I look? See image below.
By Louznmemind
I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
