Guest Fox300exchic
1)Phone conversations are over in 30 seconds flat.
2)You can go to the bathroom without a support group.
3)You get extra credit for the slightest act of thoughtfulness.
4)If someone forgets to invite you to something, he or she can still be your friend.
5)Your underwear is $10 for a three-pack.
6)Three pairs of shoes are more than enough.
7)Same work, more pay.
8)Gray hair and wrinkles only add character.
9)Wedding dress: $2,000. Tuxedo rental: $75.
10)If another guy shows up at the party in the same outfit, you just might become lifelong friends.
11)You are not expected to know the names of more than five colors.
12)The same hairstyle lasts for years, maybe decades.
13)Christmas shopping can be accomplished for 25 relatives, on December 24th, in 45 minutes.
Guest Fox300exchic
LMAO!! I bet you do appreciate the difference. lol
Guest Fox300exchic
No no...thats how YOU made it sound. lol
  • 4 years later...
    • By Cohen9966
      Looking for something similar for my 2018 Sportsman – this helps.
      If you live in New York, Come and join my group here on quadcrazy! Go to http://www.quadcrazy.com/groups/?id=1
    • By Topendcol
      First issue was fuel pump wont start once ignition has been turned on. Replaced the pump as I had one on hand, than noticed no power so replaced the fuel pump relay as that was were i traced the power to. Still nothing so further inspection looks like signal is coming from the PCM (FLR B20) but not switching the the brown wire to the fuel pump. Ive checked the operation of the bank angle sensor and it appears operational. Fuses and wiring all appear OK. The engine stop relay also tests OK. Ive been through the repair manual and diagrams but to no avail. Fully stumped, any tips would be helpful. Thanks
      Col
    • By p5200
      I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
