    • By marlon smith
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
    • By Rick Shropshire
      I recently picked up a  2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb.  Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
    • By 95kingQuad
      As the title says I am on the search for a used OEM 1995 King Quad Carb. I believe it says Mikuni on the side. If you could even help me find info on which carb it is exactly that would be helpful too, or motorcycles/other quads that use the same carb. Thanks!
    • By sunn
      Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
      My heat gun shows after 15 minute ride in ambient 91 deg temps;  690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler.  The right side plastic (where wife's leg would touch) was showing 175 degrees.  This is rediculous!.
      As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
      What is everyone doing about this problem?  Is there a replacement muffler to eliminate this issue?
