i need stuff for my 99 warrior
By marlon smith
By cruteg8
I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
By Rick Shropshire
By 95kingQuad
By sunn
Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
My heat gun shows after 15 minute ride in ambient 91 deg temps; 690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler. The right side plastic (where wife's leg would touch) was showing 175 degrees. This is rediculous!.
As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
What is everyone doing about this problem? Is there a replacement muffler to eliminate this issue?
