Federal Employees - CFC Giving to help Tread Lightly!
By Cj Winds
By Jason39
I’m having a issue with my choke when its on it runs fine when I cut the choke off the atv cuts off went to take the carburetor off and saw the choke plunger broke at the nut to screw it in could this be my issue? Do I just need to buy a plunger kit and put it on? I took the carburetor off and cleaned both jets anyway just to make sure and it’s still having issues staying on
By austinfuller22
i have a lt 230 and the e start isnt working but i dont know why
can i have some help
By Sha35297
I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
