2016 TRX500FA7 Honda Rubicon, Mil light comes on when downshifting from 4th to 3rd gear.
Go to solution Solved by Sha35297,
I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
A MIL (Malfunction Indicator Lamp) code on a Honda Rubicon indicates a problem detected by the vehicle's onboard diagnostics system. Common issues can include sensor failures or electrical problems. If it was dunked i would suspect a sensor connection problem and if the ECM got wet maybe shorted.
Gwbarm, Yes I know what the MIL light is. That is why I stated that it is not blinking to indicate a code. It is just staying on solid and there are no codes stored in the ECM. I am a mechanic who works on these daily. I have followed all of the troubleshooting tips in the service manual with no help. Just trying to see if anyone has had this issue before or maybe could steer me in a direction that I may be over looking. Thanks.
Update, I read on another forum that these bikes are prone to having the, Gearshift Return Spring Pin, break off. So I drained fluids and removed the font crank case cover to put my eyes on that pin. It was not broken and was doing its job. so I reassembled everything. Added fluids and tested again. Same issue as before. I also cleaned the idle air control valve, TPS, and speed sensors. I pulled every electrical plug and cleaned them with electrical cleaner and blew them out. Nothing has made any changes in the behavior. I notice that if I downshift manually in ESP mode while still slightly holding the throttle it will sometimes work better. Never in Automatic mode though. So I may replace the TPS to see if it will resolve the issue. Still no trouble codes either.
  • Solution
Final update on this issue. The shift pin in my previous post was not the issue in this case. After replacing every electronic component on the ATV with no change with the problem. I had to pull the engine back off completely and go through everything with a fine tooth comb. Finally I found an issue that is not mentioned anywhere in the manual, on the internet that I can fine, NOWHERE. Inside the main shaft that the dual clutch goes on there is a brass or copper ring that the feed pipe "A" stabs into. In my case that brass/copper ring was scarred up. Apparently causing a variation in the oil pressure that the computer sensed and made it now allow the bike to down shift. It never threw an actual code. The MIL light comes on steady and does not allow the bike to shift at all. I installed a new mainshaft and now the bike shifts great. I hope this helps anyone who has this issue.
    • By oztrax
      MAX 4 6X6 2008
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
    • By digrig
      Hey everyone,
