By tflack500tbx
Background,
Any Ideas?
By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
Got a Polaris Sportsman 1000 and a 570 in the garage that don't get ridden quite enough but looking forward to a family trip this fall.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
By C2INS
Hi everybody! Just wanted to introduce myself coming from NBTX. Got some used Honda TRX250's this year and have been hooked on more fixing them up than actual riding right now. Probably could use some help from the folks here on getting 2 of them in proper running order, but I'm sure I'll have to post that elsewhere!
But anyways, glad to be here and looking forward to chopping it up with y'all!
By shorty
