2008 Polaris Ranger XP Crew 700 Limited (Florida)
By quadcrazy
QUADCRAZY NEEDS YOU!
By Traytonrowland
So, I bought the machine almost a year ago and have been chasing problems. I have replaced the battery, starter solenoid, spark plug, and the starter. Since having replaced those, it doesn't want to start. I checked the carb, and it was wet as well as the spark plug. And I've searched multiple forums and cannot find an answer. So, anything that helps is appreciated, thanks.
By Johnfj44
Trying to find service manual instructions on reset of belt light on 2004 Kawasaki Prairie 700. I tried YouTube and none of the videos seem to match the wiring configuration on mine. It is running rough and the only issue I can find is that the belt light is blinking to remind me to service the machine. I can do the service but don't see how to reset the light. Can anyone provide the appropriate pages of the 2004 service manual for me?
By Uglyside38
Anyone have experience using Meier aftermarket plastics? OEM ones are shot on my quad I'm restoring and I have them "Frankenstein'd" for now...🤦🏼♂️😬
Just curious on opinions on Meier as that seems to be the only place I can find any type of replacements. (And they're pretty pricey!)
By Lance Workman
Kawasaki Prairie 700 is the machine. It’s starts and runs but has a miss. After running it til it’s warm, it’s start smoking like your spraying for mosquitoes. Has oil in the breather also. Checked compressions and getting low 40psi both holes. I know this has a decompression lobe. Any other ideas? Leak down check? I’m guessing it pretty much has to be rings. With it blowing oil back into the breather. Normal typical sign I suppose?
