take it to a tire shop and they would be able to tell you if it's repairable or not. sometimes they can put a patch on the inside, then they might treat the outer chemically to bond back together or cauterize the slice. if it's an inch long you might have to get a new tire unfortunately. a good tire shop will tell you straight up yes or no...
i got a tire of my quad bout 1 inch long hole any ideas on how to plug it would be great...i tred patch, slime, fix a flat and plugs let me know what ya got thanks
Dude you may be SOL !! If none of the above worked Time for new tires !!! All my stuff has 6 ply tires !!
    • By mehim
    • By Chucksta
      Any ideas?
    • By Drillbit
      Hey all,
      Thanks!
    • By drobbie98
      Hey all, Thanks for having me in the forum. I just purchased my first ATV and am stoked to understand more about it.
      The first stupid question will be, what is everyone's maintenance schedule? DO yo follow the recommended intervals or build one yourself based on the machine.
      Thanks in advance.
    • By El_Guapo
      Hi folks, im working on a kazuma Falcon 250 with has the ubiquitous 3 lug 8" wheels.  have a set of polaris ranger wheels and tires that i would like to use on this little atv. they are the standard 4 on 4 bolt pattern. Any recommendations for wheel adapters to achieve this? (double whammy as the wheel track will get wider with adapters). cheers!
