I have just reringed my 400ex with a wiseco kit. Im confused on which ring goes where. There is a gold/brass colored ring and a raw metal colored ring. Which one goes on top and bottom?
The top ring should have a copper color with a chrome ring face. There will be a little "N" stamped near the end gap. The N has to be facing up. The black ring is the oil scraper ring and it goes in the 2nd groove. It also has to be installed with "N" facing up. If you don't put the "N"'s up, your bike will scrape oil into the combustion chamber instead of into the lower end and you will burn up your oil and risk a seizure.
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By Trent Finnessey
    • By Dumass
