Good Morning!
Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
Thanks in advance.
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
I've been tryna find a replacement intake manifold for my 85 LT250EF because it's all hardened up but i can't seem to find one. Are there any other manifolds that would fit this model. Or how should i soften this manifold. I saw that wintergreen oil would help to soften it up but i wouldn't know how long it would last. Any other tips on how to get a tight seal around the engine intake would be appreciated.
