it runs like a champ but last week something screwed up. it clicks like its going in gear but it still acts like its in neutral. wont move at all. any ideas?
The 1984 and 1985 125M transmissions were notorious for broken shifting arms and the tab breaking off the center cases that the arm pivoted from. It's a big problem because there isn't enough there to weld with and new center cases are so expensive.....and almost any engine in the salvage yard is there for the same reason. Might be this ...
rock on man. im gonna start diggin into it after work. but for now. im late. ill keep you posted. i really appreciate your help man. youre a good dude
have a update. kinda. i havent started taking anything apart yet cuz my tools have apparently grown legs and walked off. but i noticed that if you continually up shift when in neutral if sounds like its catching a gear from the clicking sound but the neutral light stays on. dont know if it did that before. or if its supposed to. when it comes down to it i really dont know anything about this thing. also if i down shift, it makes the same noise and does the same exact thing. only difference is the neutral light turns off.
    • By mehim
    • By OldATVowner
    • By wilmpie
      hi everybody
      thanx in advance
    • By T37Mark
    • By hunky
      Thanks for looking!
