New here. Bought a 94 LT F 250 and the right side rear tire/ wheel is is leaning in. I saw this when I bought it, but figured I could fix it. After taking wheel off and removing shock the swingarm (or whatever it's called on a ATV) swings freely and has no signs of being bent. It looks like it has a longer shock on this side, but it is still the stock shock. Anyone have any ideas? Thank you
i have never seen a bike with different size front or rear shocks before. check the frame rail over the tires, where the shocks bolt in. it has to be bent out of whack or something. sounds like someone made a jump, landed hard on the rear right, and pushed the frame up, then put a longer shock on to try and drive the wheel back down... JMO
Edited by oxidized_black
