im having a problem starting my kawasaki lakota 300 i was riding it for about 3 hours it worked all good then i decided to put more gas in it. ad after that it never started and the lights dont work either i tried to use the pull starter it starts but when i add gas it turns off/stalls. and the battery is good..
All the wires and switches seem to be working fine because I just tested them and I installed a new switch to sttart it and it looks like the starter works.but the quad just doesn't want to start up.and I'm also low on oil could thAt be a problem or no..
i don't know if there is some sensor that reads low oil and doesn't allow it to run, maybe there is. i'll talk to a buddy and see what he can come up with, and in the meantime someone else here might jump in the thread and suggest something too...
the only real way to check them is with another working one you know of. you can test them but the results vary alot from spec. can you test the ignition switch first, your lights run from that. and if your lights aren't working, hopefully it's just that ...
    • By logray
      Hi all,
    • By quadnut20
    • By Jdeaton011989
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HoldenBoy
      Hi all,
