By WeeBee
By jay41198
By cruteg8
Does anyone know the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way i put it high goes into reverse and vise versa I flipped it 180 but that put the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
By cruteg8
By sunn
Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted. The atv started, but then died a couple times after repeated attempts. But when run awhile everything was ok. Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM. Just had all covers off so looks really easy to replace.
Any ideas?
