If there is already oil in it, I am going to figure the oil is injected. Any brand of 2 stroke oil will work, but you will have to read the label to make sure it works for injection units. You can also just ask someone who works where you are getting it to help you out and they can show you more about what they have and what you can use.
I have a similar question: I have a little kids 50cc with red 2 stroke oil in it. I need to add oil. Can I mix anything (any 2 stroke oil) in?
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
