A friend told me about a product called Q Bond. I used it on the radiator and it seems to have worked. I took the quad out for a little trial riding and my daughter rode it for a while so far it appears to not be leaking. Now to get in some ride time.
Mario I'm not going too call it fixed but patched. Rads are pretty high in price from 300 to 500 is what I have seen. I checked e bay. I should have kept the spare I had from the parts quad I had bought. The guy I sold it to I can't seem to get a hold of. Big if I run into him I might be able too buy it back. The Q bond is what my friend uses at his body shop I had never heard of it till then he guled an air hose with it that runs a 175 psi and it has held up. He had a demo kit and said he used it to glue all kinds of things togather he said if it broke it would be a new break and not the glud joint. I plan on getting a radiator but this will get me back to riding.
At least it gets you riding! Hopefully you can get the radiator on the cheap and have a rad shop boil it and inspect it. Ride it with the q-bond till it leaks but have the radiator on hand so there isnt much down time :) Or if it takes a while for it to leak again, put some q-bond in your backpack for the trails.
Hows your body parts healing?? Cant Q- Bond them :(
I'm doing pretty good the hand still gives me problems after the surgery. Trying to do auto body work & running a DA & hand sanding is very hard on my hand and neck. If my wife gets approved for disabilty I can quit. The friend I work for understands and knows I have to take a break when I can't hold on to the tools or sandpaper. The Q bond wont work out on the trial it has to be clean & dry. I will sooner or later find a radiator. The Q bond is no joke it's not one of these as seen on tv and it's not cheap 37.00 is the shop cost thru the paint shop suppiler you get 6 small bottles of glue & 3 bottles of the powder.
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HoldenBoy
    • By LCP92
    • By mikeexplorer
