I HAVE A 2004 OZARK 250. I pulled it out after winter and now it is not running right. It starts up fine idles fine and runs fine up to half throttle. As soon as u hit half throttle it just starts dieing(spitting and sputtering). I put some seafoam in the tank and it kinda cleared it up a little(when in nuetral) but as soon as u put it in gear and hit half throttle it runs bad again. any info helpfull.
take the carb off and clean the whole thing...and use fresh gas....check the tank screen for obstructions and check your fuel filter also..all of them can get gunky from sitting...1/4 --3/4 throttle is the jet needle and needle jet, the main jet holder may be gunky....good luck:wink:
Edited by cheriah
    • By Elk
      2002 Polaris Magnum 325
    • By BillR94
      Thank you for your time
      Bill
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By 97kingquad
