By RadRob
By kawasig
By P_syko
By KdlH
Following on from this thread;
I've finally got around to pulling the clutch cover off to have a look at the shifter ratchet mechanism. The screw holding the pinned star wheel has come loose and the wheel flops about. Unfortunately the keyway on the shifter cam has broken on both sides, I found both pieces.
Anyone had this problem?
The keyway on the cam "ramps" out, so I'm thinking of making a slightly longer key with a ramp ground into it. I'll put it back together with retaining compound. It may not work but I think it's worth a try.
By KdlH
Hello.
I'm new to the forum, I live in the UK. I have just bought a 1995 Yamaha Moto 4 350.
Generally the condition isn't too bad (I paid very little for it!), it looks quite original and all the plastics are quite good. The bad bits are no brakes, the rear axle bearings are shot and the transmission won't shift through the gears properly.
I'm not planning on a full rebuild but I would like to sort it out a bit. The transmission is my main concern. If anyone has any ideas on what might be the cause I would be grateful. I can explain what's happening in more detail if required.
Thanks everyone,
Kester
