1997 Yamaha Kodiak 400 4x4 - Smoking Bad
Hunter
I have a 1997 Yamaha Kodiak 400 4x4 it has a bad smoking problem the smoke on start up is a blue color and after it runs a while the smoke turns kind of blueish gray could this be the rings, the valves or something else, please help with any advice, P.S. there is also a little oil blowing out of the exhaust please help thanks.:GEEK:
could be just rings, could be just valves and/or guides, or all. try a compression test to narrow it down. if you have good compression, it could be just the valves or guides ... not sure how many lbs compression you should have, probably 130 anyway ... more than likely it is valves if it's blowing out the exhaust ...
Edited by oxidized_black
ok Thanks for all the input I will do a compression test and go from there, it seems to have good compression when I pull on the pull start rope as it has a lot of resistance and is very hard to pull, but thank you for all the advice and I will do a compression test to make sure I will let you know what I find, Have a Great day.
  • Similar Topics
    • By Params_sweden
      Hi!
      I got my KLF300 running again with your help a couple of months ago, at that time it was the ignition coil that had failed. It has been in use since then without issues until two weeks ago.
      When the new issue showed I was going at about 10km/h and it suddenly slowed to a halt. I started it again after that with choke and I drove it 400 meters and parked. Next time it was really hard to start, and since it was low on gas I thought that was the problem. It didn't get any better with a full tank, so I assumed it was the cold weather, and adjusted the pilot slightly.
      After that it I actually got it started again with full choke and some slight gas, I drove about 300 meters and then it slowed down to a halt again. After that, it hasn't started again.
      The compression is 165psi. The spark has good intensity, the ATV has functioned before with the same spark "intensity"/light. I *assume* that it has gas as well, there is definitely gas on the spark plug when I remove it
      I have checked the carburetor slightly, the float works, diaphragm looks ok, but I haven't disassembled it to really look for dust and such in all the small places.
      My theory right now is that it might've been some dust in the gas tank that went into the system, it's just a theory
      I'm thankful for all the help and pointers I can get, don't hesitate
      / Pär, Sweden
    • By joshua91673
      hi every one .anyone out there my issue is my kick start wont stay out  i have to have some one pull it out.  it pull out easy just wont stay out to kick it over .kicks over and starts no problem
      first post
      josh ohio
    • By Makj44
      Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
    • Get More For Your Device
  • Similar Tagged Content
  • Gallery Images
