When I dumped the oil out to recycle this morning a little filter assembly with a spring on it fell out too. I found out that it was a filter for the oil pump pickup. Ive ran it a couple times since the new filter/oil change but nothing major. Around the block a couple times. Goin to drain it today and filter the oil and reuse it. You think not having that filter for just a couple days screwed anything in the pump up?
    • By Elk
      2002 Polaris Magnum 325
    • By jay41198
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
