Jermtheworm
1999 Honda 400ex - Aaarrrr!!!
I replaced my cam and now i can't get the thing to start. What did i do wrong? I lined up everything correct. I think. Anyone with some insight that could help would be greatly appreciated.:mad:
Share this post
Link to post
i have a 99 400 ex with a big bore kit. I bought a new stage 2 hot cam for it and got the timing right. it cranks over but won't start. Looking at it today a little more...i think i have a bent valve. I pit the compression tool on it and only have 25ftpnds. not sure how to fix that. Nor do i have the tools. Also, i noticed that there are double springs on it too.is that normal?
Share this post
Link to post
A bent valve will definately cause that problem. If it is not sealing you won't get compression. As far as how to fix it I am sure Oxidized_Black has a pdf link for the manual listed and you can see what it will involve from there. Good luck and keep us posted with progress.
Share this post
Link to post
CK1999_400ex would be the best guy to chat with about this, but he hasn't been here for quite some time due to family matters. i will email him at his aol and see if he is busy. i emailed him before but never got a response ....
here is a manual in the meantime ...
https://www.yousendit.com/download/TEhWSlIzQzNveE94djlVag
couldn't upload it here, too big 124Mb's ....
Share this post
Link to post
thank you everyone who led me to the right person to get what i needed. You guys are awesome. Now i have the manual...i can get my quad up and running:) I'll be working on it tomorrow mornin
Share this post
Link to post
That's what we do here at Quadcrazy. :yes:
Share this post
Link to post
  • Similar Topics
    • By Adrian Ciotinga
      Hello,
      I recently picked up an ‘07 KFX 700. All was going well, rode it about 40 miles, when it started bogging at low speeds. If I kept the revs higher, I was just fine. Also, a persistent issue since I picked it up is the fairly difficult start (but it is abnormally cold right now and the quad is jetted for the dunes at summertime).
      Regarding the complete lack of idle, I have to rev it a couple times to get it to idle after starting it, after which it’s 50/50 whether it remains idling. I don’t have low fuel, but all of this began after I rode it pretty hard and the radiator fan kicked in. Might be overheating, just wanted to hear your opinions.
    • By Jay Reddick
      Hey guys, need some help with my 2016 Yamaha Kodiak 700 4x4.  Was riding and it started smoking below the air box and then Caught fire.  We got the fire put out quickly with a fire extinguisher.  Many of the wires below the air box got damaged.   I purchased a new wiring harness for the atv and replaced that as well as any other damaged cables or parts that burned up where the fire was.  I also replaced the regulator, the ECU, and the starter solenoid. I also replaced the stater since some of the cables that went to the regulator were damaged.  It acts like it will crank but it won’t turn over.   The fuel pump initialized when I turn the key so it’s working.  I’ve spend $1500 on parts and no luck yet.  Any suggestions?
    • By Chad Byrne
      1999 350 big bear ran with old carb on it but it leaked and most of the screws on it r stripped from having it spart so much i bought a new carb everything was the same installing it and now it won't start, any ideas
    • By Daniel Gibson
      Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
    • By Mike Johnson
      Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the,  solenoid1 is the CDI box, what is the 3rd.
