I have a 2006 brute force 750 it doesn't have the power it should and doesnt get up like it should the motor had just been rebuilt can anyone help me ___
Most of the time the cam timing is off. Set the rear cylinder on TDC "R" for rear,and set your cam timing for that cylinder with the cam lobes down. Then take a 19mm wrench and place it at 12:00 on the fly wheel bolt on the left hand side and turn the motor over clock wise until about 9:00 and start looking in the inspection hole for TDC "F" for front,and set your cam time again with the lobes down.
What happens with most people is the do this but when they start turning the motor over they see the TDC F but it's only at 3:00 and they set the cam there.It has to go past 3:00 thats why I say start looking when you get to 9:00.
Okay thayd not the problem it had a ton of power after it wad rebuilt then it went into limp mode and we reset it now its doing this
When you rebuilt it did you put new valves in it,and how much time is on the new build?
    • By toe420
    • By Adamb2025
    • By Callaway
    • By opnea
